Xantia Fog light bulb replacement - X reg 2000
rmcdonal
Unread post by rmcdonal »
Hi, I'm trying to replace the drivers side fog light bulb in my X-reg Xantia. Reading the Haynes manual it states I should remove the fog light external surround to remove the whole light unit to get to the bulb (which i believe was on the mk 1 and 2 Xantias). On my Xantia there is no surround to remove plus access to the fog light from underneath the car is limited due to the screen wash reservoir. Does the indicator and headlight need to be removed to get to the fog light bulb???
Any help is appreciated.
Stempy
Unread post by Stempy »
Easiest route to the fog lights on a Mk2 is to take the headlamps out and go in from the top. Not as bad as it sounds and certainly better than the method Citroen advise of removing the front bumper.
Lexia ponce
