xantia 1.9 td cambelt cover
toldemoldham
Unread post by toldemoldham »
Just had a new cambelt fitted but the top front cover is now damaged there is a hole the size of a 20p on top have put duck tape on to stop stones getting in but what i need to know is what year did they change covers from clip to bolt on type as this info would make it easier to to find 1.
paul.
toldemoldham
Ooopppps just realised i aint said its a 1998 1.9 td lx estate
02 c5 2.0 hdi sx estate
AndersDK
Unread post by AndersDK »
toldemoldham wrote:Ooopppps just realised i aint said its a 1998 1.9 td lx estate
And you need a bolt or clip-on type :?: :D
(in '98 major model changes were introduced)
Edit :
This clip-on type is used on 19TD until RP 06264 (up to 31jan94) :
http://www.citroen-pr.net/catalogues/il ... 143700.gif
This bolt-on type is used on 19D's from RP06265 on (from 01feb94) :
http://www.citroen-pr.net/catalogues/il ... 143710.gif
item 02 - 0320 H3 - BELT PROTECTOR
- DIESEL XUD9
- TURBO DIESEL XUD9TE
- DIESEL TURBO XUD9SD
My price list shows approx £13 (ex vat) from Citroen for this bit.
Sorry my first answer :oops:
- as this had nothing to do with the cover type change :!:
Anders (DK) - '90 BX16Image
toldemoldham
Its the bolt on type i need,been to 2 salvage yards so far and they only got the clip type but on the phone was told they was from a mk2 xantia.
paul.
toldemoldham
Thanks anders the 1 i need is the second link and at £13+vat thats not bad as salvage yards wanted £10 for a scratched and chipped cover so its main stealers for this item i think.thanks.
paul.
razzleuk
Re: xantia 1.9 td cambelt cover
Unread post by razzleuk »
toldemoldham wrote:Just had a new cambelt fitted but the top front cover is now damaged there is a hole the size of a 20p on top have put duck tape on to stop stones getting in but what i need to know is what year did they change covers from clip to bolt on type as this info would make it easier to to find 1.
paul.
Interesting - the same thing happened to my 306 TD when it had a new belt, and I saw the same thing on a mates 405D estate. Is there any reason why a mechanic might do this on purpose?
toldemoldham
The mechanic explained that some covers are more brittle than others and i cant argue with that as i cracked 1 myself doing a pug 205 diesel i once had but had no problems with the 2 pug 405 diesels and 1 of those had the covers off and on 3 times in the time i had it for 2 cambelts and a water pump.
Stewart(oily)
x 35
Unread post by Stewart(oily) »
The later ones can become extremely brittle over time, literally crumbling in your hands, they are also a right PITA to get off anyway unless the engine is out.
Stewart
