Ever since I got this car back in Feb, the clutch biting point has been right at the top of its travel.
I'm aware that there is adjustment in the clutch cable, but Haynes only talks about adjustment to correct clutch pedal travel. The clutch pedal travel seems about right, but I have yet to measure it. The pedal is certainly a good bit higher than the brake pedal.
No apparent slip in the clutch under full bananas
Any thoughts? Looks like a bumhole of a job to do - anyone know any good and less expensive garages in the Worthing area that could do the job (if the damn car passes its next MOT in Jan, I may reward it).
Cheers in advance,
Ian.
