my heater /aircon blower does not blow as hard as my daughters in the same type of vehicle she seems to have another 2 power levels on hers even though we have the same settings.IE my fastest blow is equivalent to two settings below on hers. are the blowers going west can they be repaired.
Daveyb
Synergie 1.9TD exclusive 1998
heater /Air con blower
- x 1238
If its the same blower that the Xantia uses, when its on full it has the max 12 volts across it so it should be the same speed as any other of the same type. Its unusual for it to develop a fault that makes it run slow unless something is mechanically fouling it, then you would hear a noise of some sort. They usually either work or dont!
np
davethewheel
- x 1238
