ZX No power @ fuel pump
UserError
Unread post by UserError »
Greetings.
My trusty ZX ground to a halt the other night, diagnosed by me as no fuel at the carb.
I recently replaced the fuel pump with a 2ndhand one, so immediately suspected that. However, I've just tested the power supply at the pump & there isn't any....
1 week later...
Having digested the wiring diagram, I've located the fuel pump relay, sharing the box with the ECU inside the nearside wing.
However, when I put a power supply from the battery onto the pump, it worked on the 2nd go. I then tested the discarded pump (hadn't made its way to the dump) & voila! it worked. Hmmmmm.
I reconnected the power supply & the car started - anyone had a dodgy pump or fuel relay could give me any pointers? The pump is ca 80pounds & the relay pushing 40, so I don't want to replace anything needlessly, especially as the MoT is not far away.
Jonathan
Regards
Jono
If Stupidity got us into this mess, then why can’t it get us out?
51 Clio 1.2, 01 Avensis
