406 2.1td New radiator
GSB
I have just replaced my rad. I hope I have got all the air out of the system. (I must be stupid I could not see/find one of the bleed screws as per Haynes, but bled the top one by the heater matrix.) If not what symptoms would I get. Thanks
np
Re: 406 2.1td New radiator
My Xantia was the same,no bleed screws,but the Hanyes said there was.GSB wrote:(I must be stupid I could not see/find one of the bleed screws as per Haynes, but bled the top one by the heater matrix.)
53`406 est SE Hdi 140,110k
danthevan
davethewheel
GSB
Gnerk
Does the 2.1 need a header tank to fill like the 1.9 XUD's?
I found that a 1L antifreeze bottle with the @rse cut off and self-almalgamating tape wound round the threads worked well. You can really wedge it into the radiator opening to seal it.
G'luck.
G'luck.
________________________
Renault Laguna II 2.2 dCi 2002 (bought June 2012)
Nissan Micra 1.1 96P (Mrs Gnerk)
Citroen ZX 1.9D Avantage 95N (untidy but runs wells, FOR SALE JUNE 2012)
GSB
