Having sold my '93 Xantia TD, I've just bought a '99 Xantia HDi SX estate with 97k on the clock.
Aside from what's in the service schedule, what preventative maintenance should I do to avoid known design problems in the future?
Having browsed the forum, and based on my own knowledge, the ones I've come up with so far are:
Cambelt & auxiliary belt at 100k. What about the tensioner pulley?
Change oil and filter in between 12.5k services.
Look after the front strut tops (waxoyl etc).
Keep the climate control on 'auto' to exercise the aircon regularly (apparently it's used for demisting when it's cold).
Make sure the coolant is changed every 2 years and is of the correct concentration to avoid the dreaded heater matrix leaks.
Watch for distortion on the rear calipers due to corrosion at the mounting face.
Lubricate the rear height lever.
It seems like I don't have to worry about the blower switching through the ignition - the Haynes manual shows a relay in the circuit on Xantia IIs.
Thanks in advance,
Martyn
Xantia HDi - if it ain't broke DO mend it
JohnD
- x 72
mrjohnson
AndersDK
mrjohnson
f00lzz
It's not such a big deal as a snapped cambelt on a TD anyway.. changing belts at 50K (some do!!) sure increases the running costs of a car.. especially if you rely on a garage to do the work
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
- x 1238
I think 12.5k for an oil change is to long, I'm sure that's at least partly responsible for the decline in engine life on modern cars. I have always changed mine at 5k and had engine life well in excess of 200k, in fact I sold my last XM at 292k. I know that the synthetic oil is better but it still gets dirty!
JohnD
- x 72
jeremy
- x 1238
John - I think the reccomendations are for the benifit of fleet managers who can reduce the cost of servicing but who are not particularly interested in anything above 100k as the vehicles will no longer be their responsibility.
Jeremy - I base my conclusions mainly on the mileage of of vehicles for sale. I bought my last XM at 240k at about 6 years old, I sold it two years later at 292k as previously mentioned. You still see IDI engined vehicles with in excess of 200k for sale but I have never seen a common rail with that much, the best I have seen are BMW with 150k+ but if you look on their forums many apparently suffer turbo problems which are blamed on the long oil change intervals. Certainly the fuel injction systems are much less reliable than the old ones, understandably to a degree due to the much higher pressures involved. Pump failures were quite common, I don't know if they have improved any, but could they be due to oil quality? I dont know, but all round they seem to be much more expensive to maintain than IDIs.
This is only an opinion, if anyone can show me evidence to the contrary I would be pleased to see it.
jeremy
I think you'll find the Range Rover fraternity think the BMW engines are prone to gasket failure and head cracking and are really rather weak and best avoided when not new.
I don't think the common rail systems have any parts that come into contact with lubricating oil - as all the pumps are electric aren't they?
Turbo's would be affected but there again they are also prone to damage through misuse - mainly turning the engine off when the turbo is red hot which cooks the oil nicely in them.
jeremy
f00lzz
This was certainly true of the BMW engines... of course now that Landrover belongs to Ford the engines are of course 'Ford' with the exception of their 'homemade' storm engine (TD5) which is virtually unburstable if maintained properly..I think you'll find the Range Rover fraternity think the BMW engines are prone to gasket failure and head cracking and are really rather weak and best avoided when not new.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
mrjohnson
- x 1238
- x 1238
Jeremy - Most of the information I have collected from the various forums and mileages of vehicles for sale. I have done quite a lot of research as I am looking for something 'reliable' to replace my ageing XM when the time comes - another XM would be nice but late ones are like hens teeth!
I had in mind a Rover 75 estate as this seems to be one with the least engine problems, as confirmed by my local diesel specialist, and uses the BMW engine. I wouldn't think its the same one as the Land rover uses, I think that was a TDS which I know were unreliable as I tried out two Omega's with the engine and both had faults when they were for sale!
