I am new to the TD lark and want to know what oil do you people use in your turbo diesel? I have just bought 5l of Castrol GTX Magnatec for TD engines it is 10W-40 or 15W-40 stuff. I have bought a genuine Citroen Purflux oil filter-it feels heavier than the Halfords recommended own filter, are you sure Halfords make %100 identical pattern parts?
Also I hear that modern diesel is kind of lacking in some lubricants etc that make it necessary to put an additive in your fuel occasionally? What engine/injector cleaning additives do you use regularly etc as I'm always wary about bunging any old stuff in the fuel tank.
Guru Meditation
TD Oil and Additives
JohnD
- x 72
If you want to be really kind to your turbo diesel, you couldn't do better than use a top quality oil such as Miller's semi-synthetic. If you buy your Purflex filters from Andyspares, you will be buying the same as those fitted by PSA, and at a price less than Halfords own brand. As for using an additive, not everyone agrees but in all four of our diesels, I use either Redex diesel or Millers dieselclean. It ensures that injectors stay on the top line.
Malcolm
JohnD
- x 72
