I got a tiny bit of problem fixing electric seats into my P reg Xantia SX. Seems my car is missing the wiring loom to be fitted to the seats. I did found the connector for seat heater but none for the power seats itself.
I removed front floor carpet thus exposing all wiring loom but no sign of the right connectors. I checked the fusebox and the seats 40A fuse is there and testing with a test lamp it is alive with current.
I've thought of 2 ideas to make it work.
A. Extend a wire from the fusebox run it down under seats and make new connector.
B. Tap current from live wire running along floorboard (for amplifier) and fit a 40A fuse before the seats. (if the above can't work)
I am not sure on 2 matters;
(1) There are 3 wires in the seats power connector (2 thick blue wires, 1 thin green wire). Which would be feed and ground? What the green wire for? It looks skinny it can't be feed or ground. I don't want to connect the wrong wire and short things up.
(2) Following method (A) above how do I remove the fusebox to reach the wires behind?
I'm knackered spending the whole day tearing apart carpets and figuring ideas. Haynes BOL wasn't being helful either. Anyone have wiring diagrams for Xantia electric seats to spare? Any other solution to getting it working?
Thanks mates. Cheers.
