Our 205D has been difficult to start in the cold although as soon as it is warmer it is fine. Glowplugs are what is causing it...
The engine has a set of known good 1.9TD glowplugs in it. I note that GSF specify two entirely different BERU part numbers for the 1.7D and 1.9TD glowplugs.
I'm going to get a new set of BERU plugs for it but in the meantime, does anyone know what the difference is as it sure does seem to make a difference to starting in cold weather...
205D Glow Plugs
- x 8202
205D Glow Plugs
- x 8202
That would logical... but this is Pug we're dealing with here504 wrote:There is only one fitment of glow plug for XUD engines 1.8, 1.9 or 2.1. Its a common plug used by many manufacturers.
Not sure what you have looked at but its
BBGV636 GLOW PLUG 205D/TD 5.20
Both GSF and BERU say they're different
For the 1.7D they say GV636 and for the 1.9TD GN909. Admittedly GSF only list GV636 for both the 205TD and D but if one searches GSF for the 405, they offer both depending on wether it's a D or a TD
Looking a bit deeper into the BERU site it seems to suggest that the GN909s are for use when post-start heating is employed (which is the case on a TD) and the GV636 are for "Quick-Start" applications where no post-start heating takes place as is certainly the case on our 205D. So one assumes then that the GV636 glows brighter and hotter quicker and the GN909 is a bit more laid back because it carries on heating after the engine has started...
Our 205D currently has, I know, because I put them in there, GN909s.
A set of GV636s are on order so it'll be interesting to see what difference it makes.
I'll report back!
AndersDK
Aha Jim -
But its not just selecting the glowplug type to select either glow "mode".
The heater relay must be the correct one too. You can see that - if you dig even further into the tech details on the Beru site documentation.
Earlier cars will have the standard type plugs and realy which will glow a few seconds after the lamp extinguish.
Later cars will have the circuit incorporating an engine temp sensor to extinguish the plugs much, much later. This is a natural development of the ever increasing demands on anti-pollution.
Anders (DK) - '90 BX16Image
GSB
- x 8202
Just a little update..
I put a set of GV636 plugs in and all is now OK. I did a silly thing though. In reconnecting No.1 glowplug, the termainal got a little close to the body of the waxstat and over the course of a few days the insulation on it chafed through and caused a short-circuit.
Starts on the button now...
