door locks
john alexander
door locks
Unread post by john alexander »
Hi , as I have only been using the plip to open my xantia 1.9 td . the locks on the doors no longer work off the key ( the key just turns ) is there an easy way to fix these . regards john.
x 1238
Unread post by Peter.N. »
Try pushing the key hard into the lock as you turn, some WD40 in the lock might help, otherwise you will have to change the barrels.
Mandrake
x 694
Unread post by Mandrake »
Reasonably common problem for Xantia's (and XM's), and not too hard to fix:
http://homepages.igrin.co.nz/simon/imag ... _locks.pdf
The door handle assembly on the Xantia is different to the XM (described in the above article) but once you get the barrel out they are identical and the problems and cure are the same.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
john alexander
thanks mandrake just printed it out and will have a go once I've replaced my goosed a/c compressor and burst belt., it never rains!!! regards john.
mrjohnson
Door Locks
Unread post by mrjohnson »
I had a similar problem after my plip failed.
I found the following worked:
Push the key in as far as it will easily go.
Then push DOWN as you push in.
Regards
Martyn
Mandrake
x 694
Re: Door Locks
mrjohnson wrote:I had a similar problem after my plip failed.
Regards
Martyn
That will sometimes work when the lock is first starting to play up, but eventually the sliding section seizes up altogether due to water/salt/dirt etc getting in.
The drivers lock on my Dad's Xantia didn't work at all when he got it (it would just spin around and around regardless of what you did) but after we stripped it down and fixed it, it's been 100% for over a year now.
The trick is to get the sliding section moving freely - Photo 7 and Photo 8 clearly show the two limits of movement of the sliding section. Depending on which position it seizes in the lock will either "spin" freely, (but not unlock) or it wont turn at all.
We found it needed copious amounts of pentrating lubricant spray and lots of working back and forth to free it up, then the moving parts were cleaned and greased with a light grease and reassembled. Good as new!
Regards,
Simon
Simon
1978 CX 2400
dan_the_v8man
Unread post by dan_the_v8man »
my lock works 3 out of 4 times but then the rest of the time it locks solid and i cant turn it either way, is this the same problem,
if i push down and turn it sorta of clock wise it usually sorts it. so before i go stripping it down would this suggest siezed lock or worn lock?
Cheers
Dan
Dec 94 Xantia LX 1.9 TD 116k - My first car :D
