Xantia disabling alarm
dan_the_v8man
Unread post by dan_the_v8man »
Hi
i've got a 94 Xantia 1.9td which i bought recently
it came with the alarm disabled. problem is i've since done some work on it, disconnected the battery and its re-enabled the alarm. i've manage to silence it with the keyswitch under the bonnet but apart from that i cant stop it going off and flashing the lights when ever i go near it
the plipper is dead and i refuse to pay 100+ quid for a key for a 600 quid car so is there any other way i can disable the alarm? permanantly if need be as i always have a disklok on the steering wheel
the handbook says enter the car with the alarm going off, and with in 10 seconds turn the ignition on and press the button which disabled the interior pressure sensor for the alarm but the does nothing at all
Dan
slim123
Unread post by slim123 »
Hi Dan.
I think that you need to press the button first and then turn on the ignition.
No doubt someone will put you right if I am wrong.
Dont know how to disable permenant though.
Regards
Slim.
Richard Gallagher
Unread post by Richard Gallagher »
A 94 Xantia will have a key switch to turn the alarm on/off. Its located under the bonnet just below the N/S wiper.
Berlingo Multispace 05 1.6 HDI
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
dan_the_v8man
i thourght that only silenced the sounder rather than disabled the alarm?
slim123
You thourght right, it does only shut the bloody thing up but the lights will still flash away.
Just a thought, why would you want to put a wheel lock on a 94 Xantia, it's not exactly a nickable car?? :lol:
Regards.
Slim
Mandrake
x 694
Unread post by Mandrake »
Why not get another plip from a scrapyard for next to nothing ? The series 1 Xantia's use infrared plips and it's easy to program your car to respond to a different plip. (Basically just turning on the key and pressing the button on the plip a few dozen times then turning off the key)
Also they can sometimes be fixed by someone good at doing fine soldering, as its usually dry joints on the IC's - my plip didn't work when I got the car and I managed to fix it by resoldering the joints and its still going fine a year later.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
dan_the_v8man
it is when the dead locks dont work. as they can only be enabled with the plip :D
its the lights and the sodding LED on the dash i want to stop flashing
reblack68
Unread post by reblack68 »
I think a second hand PLIP is the way to go. Maybe the one you have just needs programmed, I believe that's a simple job but I've never tried it.
You can test an IR PLIP, or any IR remote, with a digital camera. Infra-Red LEDs are visible if you look at the camera screen while pushing the Plip button. I learned that on this forum. :D
Richard
Care of a 1994 205 D.
Richard Gallagher
I had the same problem last week with a 94 Xantia which came without plips. After I reconnected the battery the alarm started going, but using the switch under the bonnet turned off not only the siren (as stated in the handbook) but headlight flashing and dashboard light etc.
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
np
Unread post by np »
Pull the main fuse out for the alarm in the dash fuse box.Cant remember which fuse,but that will stop everything on the alarm.The locking will still work though.
Used to have to do that on my Xantia sometimes to reset it. :)
53`406 est SE Hdi 140,110k
dan_the_v8man
well i got in the car again today, put the key in the ingintion and pressed the button in the manual just for the sake of it and it worked :x
anyway its sorted now
thanks all for your help! :D
weety
Unread post by weety »
there are two on e bay at the moment....they usually go for about thirty quid
http://cgi.ebay.co.uk/Citroen-Xantia-Re ... 0045758204
http://cgi.ebay.co.uk/Citroen-Remote-Ke ... 0054269979
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
