Xantia - Which Headlight Bulbs?
BonceChops
Unread post by BonceChops »
I have a series 2 1998 Xantia. It takes the same H1 type headlight bulbs as my 1996 series 1 Xantia did. Does anyone know if this is correct? I have seen listing for 1997> Xantia as using H7 bulbs. I thought the series 2 Xantia had different headlights to the series 1 model. If so does that mean my series 2 has been fitted with the earlier type headlights?
Something strange happened when Citroen introduced the series 2 Xantia, I have seen quite a few 1999 S Reg series 1 Xantia, mine is a 1998 R reg series 2. They must have had quite a few series 1 models to get rid of when the series 2 came out.
Now Citrtoenless
Stewart(oily)
x 35
Unread post by Stewart(oily) »
My Mk 2 Has H1 bulbs in it.
Stewart
f00lzz
Re: Xantia - Which Headlight Bulbs?
Unread post by f00lzz »
BonceChops wrote:I have a series 2 1998 Xantia. It takes the same H1 type headlight bulbs as my 1996 series 1 Xantia did. Does anyone know if this is correct? I have seen listing for 1997> Xantia as using H7 bulbs. I thought the series 2 Xantia had different headlights to the series 1 model. If so does that mean my series 2 has been fitted with the earlier type headlights?
Careful when distinguishing between 'series 1' and 'series 2' it would seem that there were many variations in between e.g. my first Xantia V6 was in effect a 'series 1' but with the later 'series 2' front lower to accomodate the fans/radiator extra's etc.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
BonceChops
f00lzz wrote:Careful when distinguishing between 'series 1' and 'series 2' it would seem that there were many variations in between
I usually look at the bonnet and dashboard. Both of which changed on the series 2.
Not necessarily for the better either. I have the horn being in the middle of the steering wheel as opposed to the end of the indicator stick on the series 1.
I also think the series 1 bodywork is less prone to rust - sorry, nothing to do with headlights :D
Now Citrtoenless
f00lzz
I prefer the interior on earlier models... though some of the reasons for change were understandable.. airbags etc.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
