Hi can you help me please, the front passenger seat of my C5 gave a loud crack when I tried to move it and it looks like the front l/h link arm pin has sheared the link is for the seat height adjustment. I was wondering if any of you have had the same happen to you? Or can any of you ho have access to Citroen parts can have a look and see if it is listed.
I Know I have to remove the seat but it has a airbag fitted and I also know I have to disconnect the battery the clips on the battery I'm not sure of as I'm used to the nut & bolt type not some fancy clip type so how do you remove this type of conector ???
My car is a C5 2002 2.0l hdi estate.
Cheers.
Help C5 front seat collapse
bencowell
SandyD
SandyD
