1998 Clio 1.2 Emissions
lagunanut
Unread post by lagunanut »
Help, Clio failed MOT a second time! Both for high CO. Fitted new Lambda sensor, made a dramatic difference but still high on "Natural Idle Test". First time, CO was 5.2%, now reads 1.7%, engine running a lot better but still cannot pass MOT.
Any advise on what else could affect CO at idle speed?
Garage has suggested catalytic converter or ECU or other sensors. I don't want to spend £50 on diagnotics if i can help it.
ukmobileman
Unread post by ukmobileman »
Sounds like cat is U/S but for a cheap fix try this first costs about £15 quid.
Change oil and filter! if you havent recently, you might laugh!!!! but this use to happen alot on old efi ford models and metro turbos ( late 80's to 90's), the engine oil soaks up the excess fuel vapour throught the breather pipe, this then in turn leaches back out and can give false / high CO readings :!:
Also if you can book a set time or they will CO test it as soon as you arrive , thrash the arse of it in 3rd gear for a couple of mins down the road to really heat it up!! (this was the only way to get some of those bloody fords to pass an emissions check)
oh yes i'm a ex-ford mec..............
lagunanut
Hi ukmobileman,
Your suggestion about the petrol in the oil causing the problem is spot on! I gave up trying what could have been expensive options and called in a Mobile tuner who clamped off the breather pipes and the CO levels dropped to normal. An oil and filter change then solved the problem permanently. Thanks for your expert advise.
ukmobileman
thats great , nothing better when a problem turns out to be a simple quick thing to fix.
