I have had ongoing droplink problems on the o/s on my Xantia for the past 6 months now. I have replaced the droplink four times, but after a month or two, it goes again.
I have taken these droplinks back claiming that they're faulty. Again another droplink has just failed.
Just before the first one went, I noticed a knocking on the car, which sounds to me very much like the lower balljoint or wisbone bushes were starting to fail. This has got progressivley worse to a point, where now it's a constant knock mainly on and off the power (no its not the lower engine mount). This is a problem that I'm aware of, but just haven't got round to doing anything about it, as the balljoint is such a sod to change.
Would either a lower balljoint or wishbone bush problem cause premature wear on the droplink?
I really hope so!
Droplink problems
LeeDJC
Droplink problems
2004 Berlingo Multispace HDI, 105000
- x 94
Stewart(oily)
- x 35
I would not think so, the wishbone or strut floating around a little more should not affect the droplinks, are they wearing out or snapping?
Stewart
Stewart
LeeDJC
Which part do you mean when you say swivel?citronut wrote:unlikly,i would think the knocking must be your lower swivel
regards malcolm
They are wearing out and starting to knockStewart(oily) wrote:I would not think so, the wishbone or strut floating around a little more should not affect the droplinks, are they wearing out or snapping?
Stewart
- x 1341
LeeDJC
These are pattern parts from a local motor factor. I was considering buying citroen parts, but at £42 each, I wanted to make sure that the ball joint wasn't causing the premature wear.xantia_v6 wrote:Are you buying genuine or pattern droplinks? I had two GSF droplinks wear out in less than 10,000 miles, replaced them with Citroen parts, and they lasted 50,000 miles until I sold the car.
- x 94
the lower swivel is the joint at the bottom of the hub to the lower susp arm,this is the other loint which causes knocking and clonckingLeeDJC wrote:Which part do you mean when you say swivel?citronut wrote:unlikly,i would think the knocking must be your lower swivel
regards malcolm
Stewart
regards malcolm
f00lzz
Whether OEM or pattern parts.... it is quite common for these parts to snap; usually to be honest on the ball pin itself if fitted.. this is primarily due to material defects.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
- x 94
well all the years i have been fixing car for customers i have never seen a swivel pin sheard off,even on a drop linik,so if this happens it must be due to people over tightening them,although i do remember a track rod end swivel pin shearing years ago in my early days in the garage trade,that was due to me being heavy handed
regards malcolm
regards malcolm
- x 1238
LeeDJC
Well, I have just replaced the o/s drop link with a genuine citroen one. £48 all in! All I can say is it better last longer than the others, otherwise it's going straight back!
One thing I did notice that was different with this one, is that is has the M12 thread instead of the M10 - perhaps this was contributing to the early demise of the other links?
Stewart(oily)
- x 35
AFAIK there are two different sizes of droplinks, M12 and M10 I think, If you have been fitting the M10 size to M12 car then the bolt will be loose in the hole and will likely flap about unless incredibly tight, then it may break, I think i see a pattern here.
Stewart
Stewart
LeeDJC
So do I! I didn't realise I was fitting the incorrect one, until today. I assumed (silly of me I know) that the motor factors were giving me the correct part.Stewart(oily) wrote:AFAIK there are two different sizes of droplinks, M12 and M10 I think, If you have been fitting the M10 size to M12 car then the bolt will be loose in the hole and will likely flap about unless incredibly tight, then it may break, I think i see a pattern here.
Stewart
- x 94
yep it certinly dose look that wayStewart(oily) wrote:AFAIK there are two different sizes of droplinks, M12 and M10 I think, If you have been fitting the M10 size to M12 car then the bolt will be loose in the hole and will likely flap about unless incredibly tight, then it may break, I think i see a pattern here.
Stewart
regards malcolm
f00lzz
Fortunately the problem is usually found either on the vehicle production line or during transport to dealership and then found at the pre-delivery inspection..... and of course this is never advertised to the buying public!!citronut wrote:well all the years i have been fixing car for customers i have never seen a swivel pin sheard off,even on a drop linik,so if this happens it must be due to people over tightening them,although i do remember a track rod end swivel pin shearing years ago in my early days in the garage trade,that was due to me being heavy handed
regards malcolm
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
