Exhaust clamp for Xantia XU10J4 cat to front silencer
sbraud
Unread post by sbraud »
Hi guys,
I need some help to locate the correct exhaust clamp for Xantia 2.0/16v XU10J4 1995. It’s the Cat to front silencer connection and is 7.5cm across at Cat pipe end.
I’ve called three difference branches of GSF and got three different answers and cant work out sizes from web site (below) :oops:
28279 EXHAUST CLAMP 59-5 General Use
28280 EXHAUST CLAMP 55-5 General Use
28281 EXHAUST CLAMP-54.5 General Use
28282 EXHAUST CLAMP-52.5 General Use
28284 EXHAUST CLAMP-49.5 General Use
28285 EXHAUST CLAMP-48.5 General Use
28286 EXHAUST CLAMP-46.7 General Use
28287 EXHAUST CLAMP-45.5 General Use
28288 EXHAUST CLAMP 42-5 General Use
N28226 CLAMP REAR SILENCER XANTIA TD REAR SIL CLAMP
Anyone?
Cheers
Steve
95 Xantia 20/16v 155 bhp VSX 210k
97 Saxo 1.1 SX 100k
03 S-Type Jag (sorry!)
``Only standing on the shoulders of giants - The more I know, the less I understand?? Ignorance is bliss! ''
jeremy
Unread post by jeremy »
I don't think the top 9 are Citroen parts at all - just generic exhaust fittings that will do a perfectly good job. If you want to use one of them simply take your old one along and get the nearest one or one that will do the job with a minimum of modification. (or measure your pipe and the distance to the hanging point etc)
jeremy
sbraud
Thanks Jeremy,
There’re generic from GSF online (when narrowing search to Citroen Xantia exhaust parts) and are slightly different in size. Thing is, I’m completing a web order for a few other parts and original is still on car.
Cheers
Steve
97 Saxo 1.1 SX 100k
nurkov
Unread post by nurkov »
Citroen Xantia Break 2.0T Exclusive 1999
Citroen Xsara 1.4i West Coast 1999
sbraud
Thanks nurkov... great site :D :D
Just what I was looking for. :wink:
Cheers
Steve
97 Saxo 1.1 SX 100k
