Unlocking keypad immobiliser
philhoward
Unread post by philhoward »
I've heard (from reading about Xantias, I think) that the keypad immobiliser can be "bypassed" or turned off to save keep putting the code in every time. I'm about to install an alarm with 2 immobiliser circuits and probably replacing the current immobiliser diesel pump with a non-immobilised one from a Xantia (but later on), so wont need the Cit keypad one.
Can this be done on a ZX TD? I thought i'd read that changing the code to "0000" does it, but I just have to enter 0000 instead! Is it a peculiarity of petrol cars instead, or only cars with ECUs?
Richard Gallagher
Unread post by Richard Gallagher »
The way to do it is to turn on the ignition , enter the code, start the engine (to ensure the correct code has been entered) then unplug the code pad job done.
Berlingo Multispace 05 1.6 HDI
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
