Xantia Speedo
weety
Xantia Speedo
Unread post by weety »
Hi All
My Xantia has just acquired an unusual fault.
My speedo still works fine but my odometer and my trip counter have both stopped working. Both of them refuse to accumulate any more mileage.......
Before i start ripping the clocks out (with er care and professionalism) is there anything i should be looking for in particular?
Cheers
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
x 1238
Unread post by Peter.N. »
The old 'cable driven' speedo's had plastic gears that drove the mileometer and they would strip as the mechanism got stiffer. If yours has an electronic dpeedometer with the same type of display I would suspect that the same has happened. The only practical solution is to change the instrument. You should be able to get one from a scrapyard for not to much money.
weety
took it apart tapped the oddometer which moved a little bit...put it back together and it worked....suspect the cars been clocked at some point...oh well ho hum.....
cheers for the advice
