aux belt
john alexander
aux belt
Unread post by john alexander »
Hi just changed the aux belt tensioners and idlers on my 98 xantia1.9 tdi a/c and cant figure out the route of the belt to put it back on , as I cant find my BOL has anyone got a picture of the set up , its the kind that is adjusted from the bottom not the one with the spring behind the alternator, its a harrison compressor if that makes a difference . many thanks john.
x 94
Unread post by citronut »
i must admit i play these jobs by ear,and it will only fit one way,as any other way it will either be to short or to long
regards malcolm
john alexander
Thanks malcolm. found BOL ,now fitted belt but as in other post I fitted a 1733 but it is just small enough. regards john.
x 94
the only trouble with that is these belts have to be very tight,so you might find that it wont last long before it starts sliping,and then you might not have any more adjustment
regards malcolm
f00lzz
Unread post by f00lzz »
This is the smallest belt size which is useable. Anything smaller will cause premature wear on the tensioner roller
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
