Kph speedo
Daveyb
Kph speedo
Post by Daveyb »
Hi does anyone know if its possible to change the speedo reading from MPH to KPH.possibly change speedo dial facia?
1998 Synergie 1.9TD Exclusive
Daveyb
x 94
Post by citronut »
i would have thought you will need to change the hole unit as its probably calibrated diferantly
regards malcolm
AndersDK
Post by AndersDK »
Its the same units used. The needle will rest the same place on the dial - wether you are driving mph or kph - as its still the same speed 8)
Its simply too time consuming trying to replace the dial. Chances are you will damage the instrument for good.
Its WAY more easy finding a scrapyard unit to your needs and swap the units.
Anders (DK) - '90 BX16Image
svesey
Post by svesey »
Does anyone know if the instrument panel fitted on the left in the synergie as used on the continent which shows speed in Km/Hr, can be swapped with those from vehicles with the dash on the right hand side which shows speed in mph. What is required is a vehicle for driving on the left hand side of the road with speed in Km/Hr
