Hi everyone, I have visited this forum many times over the last couple of years and have enjoyed reading all the advice given.
My trusty Xantia has developed a water leak which I cannot find the answer too on any of the forums. It is in the nearside rear footwell, I have cut the carpet out and it seems to be coming from the inside of the sill, where the sill meets the floor, does it even when it`s not raining so I can only assume water is getting trapped in there and then continually leaking out. I have looked for any drain holes on the sill but to no avail, any ideas gratefully received.
Keith
Xantia water leak
Stewart(oily)
- x 35
My mates VSX got water in the rear footwell, it was traced to the plastic moulding at the back end of the rear window, we temporarily taped it up and its still dry. tailgate seal leaks in estates can manifest themselves as wet footwells too, good luck.
Stewart
Stewart
- x 94
somtimes when people remove the inside door trim(card) to gain acces to the inside workings of the door they dont put the membrain back properly,i fixed leak on a customers car where he hd water comming in from behind the door trim and over the door shute seal,i found water was being diverted past the plastic cover over the back of the speaker and into the car,i stuck some plstic sheat from inside the door above the speaker to divert the water bck into the door,so it would go out through the drain holes in the bottom of the door where its ment to go
regards malcolm
regards malcolm
davetd
