Morning People
How many times a minute should a healthy regulator do it's thing and should it be a quick click or a drawn out woosh?
cheers
davetd
Regulator Cycles Xantia
davetd
93 Xantia SX TD Manual Metallic Grey 145,000 Non Anti-Sink
- x 94
paulbx
ticking frequency
more than 1 every 20 secs means its on its way out. Healthy Accumulator can go over 60 secs. As for the "whoosh" thats unrelated I think (mine does that too - sometimes)
Broomie(paulB) Xantia Hdi 90 estate
jeremy
- x 3
Sound accumulator is vital - especially on a Xantia with anti-sink and ABS or other suspension complications.
If after fitting a new sphere it still ticks rather often the non-return valve in the regulator has probably worn its seat - it can be re-seated at no cost - full instructions on here.
Accumulator should be able to raise you if you run the car, let it settle, turn off the engine and sit in the boot. Car should sink then after 30 seconds or so rise to its original position.
jeremy
davetd
Jeremy
Acc sphere changed 3 months ago, and 18 months ago by previous owner
Found one of your old posts on the search facility; so
Depressurise Hydraulics
Acc Sphere off
Brass punch to the ball behind where the sphere sealing ring goes
and then back together
Let me know if i've missed something
Many thanks
davetd
Acc Sphere off
Many thanks
davetd
jeremy
- x 3
That's correct - one smart tap only - otherwise you get overlapping seats that are worse than what you started with.
If you can do it with the regulator in place be prepared to use something other than your eye to collect the ball in when it falls out.
And of course the usual health warning - prop it up properly or it will kill you.
Incidentally if you get a face full of LHM when you remove the accumulator - its flat. It should not be holding any - so when its depressurised - very little should come out - but it may continue to drip slowly - which I think is due to the stuff syphoning through the pump.
Good luck!
Good luck!
jeremy
davetd
Jeremy
I finally did as you suggested this morning but it hasn't made any difference.
With the sphere off I removed the 8mm bolt and plate, removed, cleaned, replaced and then tapped the small ball bearing at the top is that correct
regards
davetd
regards
davetd
jeremy
- x 3
have you tested the accumulator - by sitting in the boot? Does the ticking frequency change when the car is fully raised (suspension spheres function as accumulators)
If the car doesn't rise or change frequency then the accumulator is faulty.
If all is OK then you may have a leak elsewhere. This won't be a leak to the outside but an internal leak - and you may be able to find it by removing the return pipes.
The most likely candidates are the front struts (highish mileage - they seem much more durable than BX ones) or the regulator itself (again unusal but possibly its scred a valve or is slack)
Are you 100% sure there is no air getting into the LHM before the pump? The hose from the reservoir can crack or its ends either work loose or become ragged when removed. The ends must be properly clipped - and not turn when twisted. Air in the LHM will cause all manner of problems.
jeremy
robyoz
