Next question ...
SteveG
Next question ...
Unread post by SteveG »
Whilst probing around under the bonnet looking for causes of my starting problem earlier today I found a small rubber hose hanging loose. It comes from the front of the fuel filter - between the two electrical connections - but where does it go to?
Anyone fancy popping out to their car to take a look for me?
jeremy
x 3
Unread post by jeremy »
Its meant to be like that. Its the drain tube so that you can drain off water and dirty fuel without getting it inside the starter.
jeremy
x 94
Unread post by citronut »
yep its also usfull to drain the filter down before fitting a new one
regards macolm
SteveG
Thanks guys :P
