Hi, any pictures of the area that needs to be lubed to free the vertical movement?
It's a MK2 XM.
Tnx.
Height corrector linkages
jeremy
- x 3
Don't need pictures - trace the linkage from the anti-roll bar, and clean and lubricate everything that moves or looks as though it should. This includes the rod going into the corrector (has pipes going into it and is round) and any bits of the control lever mechanism that are handy.
Filthy job - things like cans of spray grease, brushes, oil cans, chainsaw oil (stickier than engine oil) are all handy as well as wire brushes and rags - as well as goggles for you.
Health warning may have been given - you are messing with the mechanism that will cause the car to drop - and if it does the car may KILL you - you wouldn't be the first.
jeremy
nino1
jeremy
- x 3
- x 94
