Intermittant Wipe Xantia 1.8i
Malcolm
Unread post by Malcolm »
Sister-in Law's Xantia intermittant wipe does not work. Stopped working other day. Both other speeds work OK. Anyone had this problem? Any suggestions? Cheers
Malcolm
'98 Xantia Estate LX - RIP 13/08/16
'08 Renault Trafic 115dci
jeremy
x 3
Unread post by jeremy »
Does the self parking work properly? These things rely on the self parking switches in the motor and simply provide a pulse to get the motor going and leave the rest to the parking mechanism.
Otherwise check all the wiring but its probably the timer which is probably located in the column stalk. This doesn't seem to be a common fault so a good check of all plugs on the motor and the switch is worthwhile.
jeremy
Malcolm
Yes, the parking works fine. Thanks for the reply. I'll have to have a look next time I'm over her way. Just thought that there may have been something obvious, cheers.
Malcolm
