Hi all
Does anyone know if all the 2.1TD citroen engines have the EPIC injector pump with the drive by wire on them or are there some out there with the good old fashioned 1 wire to the shut off valve and a proper throttle cable to the pump?
Did the peugeot 2.1TD have the epic as well?
Rob
2.1TD engines
h2ocooler
2.1TD engines
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
KP
- x 27
davethewheel
BonceChops
That sounds right to me, the Peugeot 605 2.1TD does not have the EPIC, it is a normal good old mechanical pump.davethewheel wrote:i might be wrong but as far as i know all xantia 2.1td's have the Lucas epic fly by wire pump as well as peugeot 406 2.1td engines, earlier xm's had a mechanical pump.
regards dave
Now Citrtoenless
Now Citrtoenless
h2ocooler
Well looks like i have to find 2 dead XM's then, want then to convert to marine engines but dont want electronics on them, too much agro in a marine enviroment!
Rob
Rob
KP
- x 27
Why not try retrofitting a different pump, say a bosch 1.9td pump? they are meant to be the hardiest pumps in regard to the viscosity they will take fromthe incoming fuel which could get quite cool on a marine application and give you much better scope for replacement and finding spares in the future?
NiSk
Hi H2O cooler!
I converted a Peugeot 505 diesel to marine and ran it in a half-planing 25-foot Norwegien boat (a Sandefjord Bever 740). Worked great and gave about 60hp. BTW, its the same block that the Volvo Penta MD21 was based on. Do you intend to use a turbo? (watercooler?)
Yep, you'll have to start looking for a pre mid '95 XM TD12 if you want a 2.1 litre with mechanical injection (or a similarly aged Pug 605 diesel).
//NiSk
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
h2ocooler
Hi NiSK
Yes looking at a Turbo Diesel for the power, been looking on a marine website that marineise the 1.9TD citroen lump, they dont watercool the exhaust manfold or turbo just inject the water into the pipe after the turbo (as with all marine engines)
Does anyone know if the 1.9TD and 2.1TD blocks are the same or fit the same bell housings??? if so its easy then, i can buy a ready made adaptor for the 1.9TD
Rob
Rob
h2ocooler
thanks NiSK
Going to send an Email to him.
Are the 505 diesels the same as the CX do you know??
Regards
Rob
Regards
Rob
NiSk
jeremy
- x 3
I think the 505 engine is a derivative of the Indenor engine developed by Peugeot in the 60's or 70's and built by a subsidiary company in a factory set up with French govt money. Indenor - probably something like INDustrie Du NOR(th) - and certainly nothing to do with India - or even the West Indies. These had codes like XD88 (2 litre fitted to 404)
jeremy
NiSk
The more you dig into the history of motor cars, the more facinating information you uncover.
For example, the PSA range of indirect injection engines (such as the TD12) became popular and led the market for many years due to the unique design of the pre-combustion chamber.
On my old XD2 engine (that I converted to marine use) the words "Ricardo Comet V" where cast into the cylinder head.
"Oh" I though - Italian design?
Wrong! English design!
Check out the following link, and note the bit about Citroën launching the worlds FIRST diesel production car in 1935!
http://www.ricardo.com/investors/compan ... anyhistory
//NiSk
//NiSk
NiSk
Just been checking up on bellhousings -
The 2.1 XM and Pug 605 diesel use the ME5 gearbox
The 2.1 Xantia uses the ML5 gearbox
The 2.1 Pug 406 uses the ML5 gearbox
The Synergy diesel uses either the ME or ML gearbox, and that has the 1.9 diesel!
Not conclusive, but looks like you might have a way out!
//NiSk
//NiSk
KP
- x 27
