Sphere recharging kits stil avaliable?
ekaftan
x 8
Unread post by ekaftan »
Living in southamerica, and having limited access to quality non-original spheres, I want to try and refill originals.
I read the archives and there is a lot of info on recharging kits that no longer are sold.
Is there any recharging kit still for sale?
Thanks.
AndersDK
Unread post by AndersDK »
The Italian company Valprex used to be the source of sphere recharge equipment.
You may try contact the Italian Citroen Car Club.
There is a good chance some member will know where to source the equipment these days.
Anders (DK) - '90 BX16Image
andmcit
x 30
Unread post by andmcit »
Tecnosir valprex do/did the kit - how's your italian!?
http://www.tecnosir.com/
There's a german or dutch Ds club that lists a kit IIRC
- can't find it at the moment.
Andrew
ekaftan
x 8
andmcit wrote:Tecnosir valprex do/did the kit - how's your italian!?
Andrew
Italian is very much like spanish. I managed to find the kit and the 'contact' button and send an email.
(I then realized there was and 'english' button :)
swiss_steve
Unread post by swiss_steve »
Pleiades (U.K.) re-charge spheres; e-mail: [email protected] or look at their website: www.citroen-hydraulics.com
Proud owner of two Citroens:-
'R' reg 1998 Xantia 1.9 TD Temptation Estate.
'N' reg 1996 ZX 1.9 TD Aura Estate.
x 94
Unread post by citronut »
spheres are not indefintly rechargable,as the nylon blader deteriorates with age,then can no longer hold nitrogen
regards malcolm
jeremy
x 3
Unread post by jeremy »
Seems niot much age - as I found out yesterday changing my BX accumulator - which I fitted as a precaution less than 2 years. Well and truly destroyed its diaphragm as I found out when I got a face ful of LHM!
jeremy
goldfinche
Spheres
Unread post by goldfinche »
Hello. Jeremy you are not alone I have replaced 2 acumulators and neither lasted more than 18 months and they were new, not regassed. Not genuine Citroen but well known make. I wonder if there is a reason for this? The regulator pressures etc. are correct. Any thoughts anyone?
Cheers.
Geoff.
1991 Turbo diesel automatic.BX.
1993 ZX td. slowly dieing.
Mandrake
x 695
Unread post by Mandrake »
Well I replaced my accumulator sphere 18 months ago when I first got the car, (the old one was down to 20 bars) and its still fine!!
I can switch the car off, wait 10 minutes, sit in the boot and it will lift me back to normal height quite happily... :)
Genuine Citroen sphere though! (3rd party ones aren't generally available here in NZ as far as I'm aware, its either genuine, or get them regassed, and I wouldn't bother to regass accumulators)
Because the accumulator sphere is under the most strain (running at full system pressure all the time) even if you regass or use 3rd party for suspension spheres, I'd still go for genuine for the accumulator as it is your main source of emergency braking....(and theres not much price difference at places like GSF anyway!)
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Father Ted
Re: Sphere recharging kits stil avaliable?
Unread post by Father Ted »
ekaftan wrote:Hi,
Given the cost of recharging equipment - wold it not be cheaper to have some spheres posted to you after all spheres are about £20 / each new?
ekaftan
x 8
Father Ted wrote:
ekaftan wrote:Hi,
I am now buying just the valves and trying to make my own recharging valve... If it fails, I'll buy the recharging equipment. It will replay itself in no time with two VSX Xantias :)
