Xantia V6 auto question - 5 gears!!
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
well, not quite ;)
but, for example, when my xantia is warm, I manually select 1st, leave it there till about 3000 Rpm, then knock it into 2nd.. the revs drop, I continue, they drop again (about 500) , I change up then 3rd, then drive, and all is normal...
anyone else have this quirk?
is it a quirk?
John g
x 1484
It's probably the torque converter locking up at some predetermined speed, which gives the impression of another 1/2 ratio. Guy I used to share a lift with had a Scenic DCi auto, and that appeared to have an extra ratio too.
jgra1
(Donor 2021)
x 36
thanks Rich
DHallworth
x 166
Unread post by DHallworth »
my old V6 Xantia did this too, so i am guessing its just a quirk!!
David.
Stempy
Unread post by Stempy »
Mine's the same :D
Lexia ponce
jgra1
(Donor 2021)
x 36
8)
alan s
RIP 2010
x 6
Unread post by alan s »
I have seen debates about a "warming up" feature that Pug 406s are supposed to have in their auto transmission systems that has some bearing on revs at lower temps etc, so might pay to ask the question of some Pug owners as I would imagine the 406 and Xantia would share a common drive train.
It's possibly more of a feature than a quirk.
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
jgra1
(Donor 2021)
x 36
Alan, thanks,
yes it does this anyway, holds first for a lot longer when cold...
I asked about this when I got the car as I was slightly baffled..
yeah certain the drivetrain is same for both... except the lucky 406's can get manual trans ;)
Am i right in thinking French V6 xantias cuold be manual? ..
too much hassle to bother changing I think... I quite lilke the auto, but... a manual would be nice...
alan s
RIP 2010
x 6
I think we checked this out a while back and for reasons best known to themselves, we came to the conclusionXantia V6s are all autos.
We were discussing at the time which versions came in Activa and it seems we got a few out here that you didn't get there namely manual CT Turbos in Activa although they were in very small numbers.
Alan S
RIP Sept 19th 2008.
micitroen
Unread post by micitroen »
This, higher rev change up when cold is supposed to aid 'Warm up' as the wife's CRX auto has the same feature. Slightly off topic re Activas but there are also the TD Activas sold on the continent... only available in LHD.
Mike
1993 BX TXD EST mmm. nice. 1990 Bx 19TZD Auto Lhd (now lives in France) 1998 Xsara 1.9d lx.
