Hi all.
Well i finally got the bugger off last night
took an age and some gentle sawing as well but finally did it.
Got the new one on bar about 8mm of it and its stuck to buggery and wont go any further
Has helped no end with the annoying see-sawing of the engine but it does transmit more vibrations thru the body, i think due to not being fully seated.
Im thinking of rigging up a thick plate on one side of the mount, and then one plate with an exhaust Vband clamp used to keep the force on the outter metal edge, and then tighten it up as best i can with ratchet and hand vice grips. this should be able to get it in near enough all the way i hope boy is it a bugger getting the new one in
Has anyone though about sawing INTO the new one to make it a tiny bit smaller and easier to fit in as once its in its not going anywhere really is it??
Some pictures are here if anyone wants a nosey
www.coop.talktalk.net/Xantia_Repairs
Ta again all
Will
