Citroen XM 2.1 TD coolant drain plug
Blondie
Unread post by Blondie »
Can anyone help with locating the coolant drain plug on my Citroen XM 2.1 TD 1997 estate please? Is it the thing that might be a drain plug on the back of the cylinder block, next to the electronic oil level indicator? Just wanted to check before undoing it . . . . Thanks!
x 1240
Unread post by Peter.N. »
My, another XM in the next county! I am not aware of the existance of a drain plug, I just disconnect the bottom hose. Mine has got hoses held on with jubilee clips, I suspect yours being later has got the bayonet type fittings.
