I bought a 1992 ZX 1.9d 2 days and everything is fine. Drove the car in to town today fine and when I returned put the key in the ignition and the dashboard lights came on but it would not start (i.e. starter motor not spinning).
To cut a long story short RAC chap came out run a direct positive supply from the battery to the starter motor and she burst in to song. This is how I have been successfully starting it from then on.
So I believe the problem to be with the ignition switch after researching this wonderful site and want to know is there an easy ay to replace the switch alone (without changing the barrel) or can I snip the cables (is there only 2) from the ignition switch and wire a new switch???
If so does the switch have to be heat resistant or can I use a basic toggle switch???
Some one mentioned fitting a relay , can some one explain the type of relay, where I would get one, the connections please and IS IT SAFE????
Is it an easy job to do or can someone recommend a good garage and rough price in the Cheshire area (ideally Crewe)??
Thanks for your help in advance!!!
