Hi All,
Finally got around to tackling the timing belt on my Xantia (2 litre 8 valve petrol) and found this:
http://homepages.igrin.co.nz/simon/imag ... rpump1.jpg
http://homepages.igrin.co.nz/simon/imag ... rpump2.jpg
Looks like the water pump is leaking
The brown substance is sticky gooey crap which I presume is leaking coolant mixed with grease and oil ? There is enough of this stuff built up that the edge of the belt is actually running through it! Am I likely looking at a new water pump here ? Won't be able to get it off to inspect it until tommorow so I was looking for some comments on it.
Oh and by the way I notice exactly the same problem DoubleChevron had with his - the timing holes don't line up. With the pin in the crankshaft pulley the camshaft pulley hole doesn't line up by about 10-20 degrees....
Regards,
Simon
Xantia Waterpump
Xantia Waterpump
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
Not just petrolheads, any PSA motor with a cambelt-driven waterpump!
They are such a pain if you have to fix them separately.
And the same applies to the camshaft and crankshaft end seals while your at it - it's such a minor job while you've got the cambelt off, you'll kick yourself if you don't do them.
//NiSk
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
