More Synergie Electrical Woes
Danny04
Unread post by Danny04 »
Can anyone shed a light on a small matter of low level warning light for the cooling system on a 1.9td VSX Synergie. This problem being that the warning/stop light constantly flashing whilst driving and very intermitent and it is driving me crazy as the local Citroen garage say there is nothing wrong with the cooling system. Somebody please say you can help. :?
x 1240
Unread post by Peter.N. »
There should be a low water sensor in the header tank if it has one, or alternativly in the radiator. Remove the plug and if its anything like most sensors, it will come out if you rotate it half a turn anti clockwise. Give it a clean and refit it. Sometimes crud in the water will insulate the probes.
