ZX Disc Size
rossnunn
ZX Disc Size
Are all 16v discs 247mm disks? or did they also come in 266? if so will the 266's fit on 248 hubs?
jeremy
- x 3
Quinton Hazell's catalogue shows the 16 valve as having 266mm diameter discs and all the others being 247mm. The 266 mm ones would seem to be ventilated which means wider calipers.
http://www2.qha.com/catalogues/QH15.pdf
jeremy
Village
James.UK
I swopped volcane calipers onto my ZX Avantage, but had to have the 13 inch wheels replaced by 14 inch Volcane ally's to accomadate my vented discs..
it was still a very close fit...
I think you would need at least a 15 inch wheel to take the 266 disc, but I don' think the calipers need to be any wider for vented discs.. (Unless the Volcane I swopped from had abnormaly wide callipers of course)..
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
jeremy
- x 3
Kitch
All ZX 16v's had 266mm discs, except the very last continental models with the Xsara VTS engine which had the 283mm versions as fitted to the Xsara.
Lesser ZX's had the solid 247mm discs with bendix or girling calipers, and the TD's and some petrols had 247mm vented with girling or ATE calipers.
Volcanes....I'm not sure. Would have thought 266mm to be honest.
Hubs should be to same, but offset of the 266mm is shallower than the 247mm IIRC.
1991 Citroen BX 16valve
1998 Citroen Xsara 1.9TD SX
1993 Peugeot 106 XSi
1995 TVR Chimaera 400
rossnunn
Great thanks for that, that info might be useful as a sticky??.Kitch wrote:All ZX 16v's had 266mm discs, except the very last continental models with the Xsara VTS engine which had the 283mm versions as fitted to the Xsara.
I upgraded from standard to TD fronts some time ago, running on 14" Volcanes, now I have upgraded again to 16v fronts & disc'd rear's. (not done the fronts yet so can't tell you if they'll fit under a standard 14" alloy) also fitted the 16v servo - I now have some 17's to go on
James.UK
The bigger discs would not fit into my 14 inch Volcane ally's, so I had to use the 247 vented disc..
I also had to get a bigger master brake cylinder fitted..
8304
i have girling calipers on the front of my zx td does this mean i have the smaller 247 discs??
also, are the bigger xzara vts discs and calipers interchangeable with the zx?????? bet they would be pretty effective....
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
jeremy
- x 3
rossnunn
