citroe4n xsara hdi 2001
1939
Unread post by 1939 »
hello every one i wonder if any of you can tell me the INSP spanner light, CITROEN PICASSO dose the spanner stay on the clock all the time i reset it to zero the spanner dose not flash now but it seems to just stays on now but dose not flash i thought after re setting the spanner is would disp after it was re set thanks for any one that can help
pie eater
Unread post by pie eater »
If it's anything like the C5, it illuminates when you turn on the ignition, along with the miles to next service. They both go out and the normal odometer and trip then illuminate. If the distance is less than 1000 miles, mileage and spanner flash for five seconds. Then, normal odometer and trip illuminate, but spanner remains lit indicating a service is due.
On the C5 you can reset the service indicator by holding a button on the dash whilst turning on the ignition - not sure if this applies to the Xsara/Picasso.
C5 2.2HDI Exclusive
Xantia 2.0HDI SX
Eunos Roadster (I'm sure theres enough room under the bonnet for that HDI)
1939
thanks for the imfo pie eater thanks a lot :)
