Have a look at this.
A Mk2 inside and a Mk1 ish outside? Look at the mileage as well!!
http://cgi.ebay.co.uk/citroen-xantia-HD ... dZViewItem
Regards
Xantia HDI on ebay?
howiedean
Xantia HDI on ebay?
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
den169
matt
Ross_K
- x 110
andmcit
- x 30
Ross_K
- x 110
You see a lot of 1999/2000 models here in Ireland with black strips on the bumpers...
http://www.carzone.ie/usedcars/index.cf ... rID=396648
http://www.carzone.ie/usedcars/index.cf ... rID=320533
http://www.cbg.ie/Car_detail.asp?CBGID=506099&ID=778517
Must have been a poverty spec thing...
andmcit
- x 30
I prefer the black contrast - as the Citroen designers intended it to be from
the outset - my white S1 estate looks fabulous with it's kick up in the
waistline and all the windows in shadow - seen an all white S2 equivalent
and felt violently ill!
FWIW, IMHO the last of the S1's (95-96) are the best looking Xantiae with
black trim contrasting the shape better and fitted with non fading tail lamps.
For me although I've got a few S2's the bonnet grille on the S2 looks a tad
Xsara and a bit pointier...
Andrew
Andrew
ACTIVE8
- x 6
This seller appears to have bought, and sold many cars, looking through the feedback they are vehicles that require some work done to them.
Looking at the other examples in Ross-K post it appears that there were other Xantias made without colour coded bumpers. Although surely these are to special order, and Taxi specification.
When a modern car does not have colour coded bumpers it does not look as good as one with them.
If I had not seen the other examples of unpainted trim, then I would have concluded that the car has had some bodywork done, and then the owner could not be bothered to get the items painted.
As the car has covered 280k I still think that they might have changed items, because this vehicle has covered a lot of mileage, and had previously been used as a Taxi, with that sort of mileage, and being used as a cab, there would be damage that would need attending to. This specification has helped the seller to get it repaired cheaply, but the unpainted finish does not look good.
philhoward
weety
didnt they all have air con by that age? seem to recall it was something like P reg onwards it was fitted as standard even to poverty spec...
if it was used as an airport taxi (or some such thing) it might even be a good buy at £600 (but probably not
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
Ross_K
- x 110
Sold for £620. Looks like he made a bit of a profit since he bought it last month...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0017247695
weety
probably helped he didnt mention the 'steering pump' whine.....
nick
Not necessarily, my bog standard 97R TD doesn't have aircon. By that stage the "base" version was only available to fleet buyers in the UK, mine was part of a huge batch of Xantias sold to Midland/HSBC bank. If they ordered in large enough quantities I think they could more or less ask for whatever options they wanted (or not).weety wrote:didnt they all have air con by that age? seem to recall it was something like P reg onwards it was fitted as standard even to poverty spec...
weety
ah ok...but on the upside my air con has never worked properly (long tale of woe) and it makes it hard to change the oil filter (the first time).....hmmm maybe i should buy cars that people have actually servicednick wrote:Not necessarily, my bog standard 97R TD doesn't have aircon. By that stage the "base" version was only available to fleet buyers in the UK, mine was part of a huge batch of Xantias sold to Midland/HSBC bank. If they ordered in large enough quantities I think they could more or less ask for whatever options they wanted (or not).weety wrote:didnt they all have air con by that age? seem to recall it was something like P reg onwards it was fitted as standard even to poverty spec...
