Citroen Xsara oil change?
boroboy
Unread post by boroboy »
Hi all,
I own a 99 Xsara 1.4 LX with 89,000 on the clock. I've just changed the plugs & now It's due for an oil & filter change, would 15/40 semi be ok to use?
Thanks.
JohnD
(Donor 2022)
x 72
Re: Citroen Xsara oil change?
Unread post by JohnD »
[quote="boroboy"]Hi all,
quote]
Yes! But don't leave it in for as long as you could a synthetic.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
boroboy
John,
My car has just covered 5,000 miles since it had it's last oil change, I intend in changing the oil every 6,000 miles. Just thought as the car has covered over 60,000 miles I'd use a slightly thicker oil 15/40, don't know what the manual suggests from new?
jeremy
x 3
Unread post by jeremy »
Somehow I think the manufacturers development budget is greater than yours - and so I'd stick firmly to their recommendation.
All Citroen engines last extremely well when lubricated in accordance with their recommendations.
jeremy
JohnD
(Donor 2022)
x 72
It's sensible to change the oil at 6000miles. The recommended oil for cold climate is 5/30 and for moderate climate 10/40. Both semi-synthetic. An alternative for moderate climate is given as 15/40.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
boroboy
John D,
Thanks for that, think I'll go with the 15/40 semi, all things considered.
