Hello,
I've replaced the two front strut tops on my Xantia, do I need to bleed the system to get fluid back into the struts? or do I just close the pressure release bolt on the accumulator and start the car?
Thanks,
Fangy.
how to bleed a xantia
philhoward
- x 94
f00lzz
Which bleed valve would that be then??????citronut wrote:set the hight to maximum,start the engine,hold the revs up to about 2,500 and keep it there for about 30seconds,then close the bleed valve
regards malcolm
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
fangy
- x 94
Homer
- x 16
fangy
- x 94
The car won't rise with the valve open.Homer wrote:citronut wrote:with the presure release valve open after the car has finnished rising,
You want to tighten it, then start the car. Move the suspension up and down a few times and that's all you should need.[/quote
the idea of leaving the valve open for about 30 seconds after starting the engine then shut the valve allows some air to escape,in all th years i have worked on and around citroens i have always done this and all of the citroen garages i have worked for do it
regards malcolm
