Hi after spending a good 2 hours trying to get my ZX's hubnut off I took the whole hub & driveshaft off as one piece!
I can now confirm that the diesel driveshafts do not fit petrol gearboxes. They are not as far out as one might expect though, the spline is about 1 > 2mm bigger in diameter on the diesels.
ZX Driveshafts
rossnunn
Does anyone know if this info is right:
1.4 (Small Driveshafts)
Cannot split outer CV joint
Can split inner CV joint
1.9D (Large Driveshafts)
Can split outer CV joint
I've looked through the Hayes BOL but it doesn't make it very clear
(I think you can see where I'm going with this)
- x 8309
Sounds about right to me...
Not too much of a problem though. If you want to replace a CV boot on the outer, a cone and stretchy boot makes the job easy and saves distrurbing the inner.
Take care if you do split the inner though, if the bearings fall off the tripod you are then faced with the job of carefully finding all the spilt needle rollers that fall out and reassembling the joint. Wrap it in something to prevent a fallapart...
rossnunn
