Doors
DirtyGertie
Doors
Unread post by DirtyGertie »
Hi Guys/Gals
Does anybody know how to cure a loud clacking noise coming from the passenger door ?
Vera 2001 5dr 106 1.5D 56k
Gertie 98 5Dr Dturbo No Cat or EGR over 130K R.I.P lost fight with 7.5 Truck :(
pugxpert
Unread post by pugxpert »
grease the door striker and see how it is,they get dry and creak with body flexing
EP6T petrol turbo nice engine in the 207 GT and the new mini....
DirtyGertie
Sorry Guys :oops: should have said that the noise happens when i open the door seems to be coming from the door strap
matt
Unread post by matt »
Try changing the pin on the strap,as they wear they get more and more noisy,then spray grease it!
92 205 1.9 GTI(MODIFIED,SORRY )
1996 VOLVO 850 2.5 5CYL 10V
1999 EXPERT VAN TD - WHITE !
No more car's thanks!
pug_owner2002
x 3
Unread post by pug_owner2002 »
Strange that this post should come on as I've just fixed this on the passenger door on my 306 this weekend.
There are 2 nuts that hold the door strap to the door and 1 nut was loose and the other 1 was missing.
A replaced the 1 and tightened the other and this has cured it.
Let us know if this is the same problem on yours.
R Reg Phase 2 306 DTurbo (Blaze Yellow) (Sold)
X Reg Phase 3 306 1.4 LX (Sold)
03 Renault Scenic Dynamique +
03 Seat Leon 1.9 TDi
52 Nissan Almera 1.8 sport+
DirtyGertie
Alas :( the problem is not the same... on closer inspection of the door strap it doesn't seem to operate smoothly causing the pin to click in it's mounting
does this now mean some mechanism in the door needs changing?
matt
The pin is clicking because its slack,the spring is very tight which is why its so noisy,change the pin and if its still bad change the strap etc as the hole could be worn that connects it too the pin/car.
DirtyGertie
cheers matt
will i be able to get the pins from GSF or is it dealer only?
matt
I think they are dealer only,pretty cheap too which makes a change!
