Hi Gang,
I think I have a sticky brake caliper as I'm getting a slight judder when braking lightly.
I've replaced all 4 discs front and rear recently and the pads. Also cleaned up the front and rear of the calipers where they connect to the hubs.
AS a result of a brake caliper bolt shearing one day ( another story) due the alignment changing with a build up of oxidise aluminium alloy.
Vehicle details on my signature.
Any thoughts would be greatfully appreciated.
Cheers
Kenny
Refurbishing Brake Calipers.
KennyW
- x 164
C3 1.4 petrol (SWMBO)
KP
- x 27
www.brakesint.co.uk have all the seals and bits you will need for them and cheap as well
philhoward
I wouldn't have though a sticky calliper would have caused juddering; pulling to one side, yes.
I'm assuming the disc mounting surfaces were spotlessly clean when you replaced the discs, and they were decent quality discs as well. It only takes the smallest amount of muck anywhere to send the discs out of true. I have had new "no-name" discs which didn't run true (I was in a hurry...).
Quick test would be to take the wheel(s) off,and spin the disc; a small amount of runout can usually been seen with naked eye, especially when it has something fixed to compare with (like the calliper/pads); usually you can visibly see the mfrs recommended runout, especyally with new discs.
Mandrake
- x 694
I agree... the caliper couldn't cause "judder", it must be something to do with the pad or disc surfaces...
Regards,
Simon
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
KennyW
- x 164
Thanks Phil and Simon,
I've only noticed this since returning from hols in France , there were no problems then but a thought
Could the high temps in France, allied to the windy roads where I was staying cause problem with the discs
They were a brand make.
Also I snapped a drop link on hols but during an inspection I noticed 1 of the lower ball joint rubbers was badly damaged. Could this be a possible cause
Cheers
Kenny W
Cheers
Kenny W
philhoward
KennyW
- x 164
Thanks Phil
Have a new one , will change same and see what happens.
Cheers
Kenny
Cheers
Kenny
