so far from Citroens !
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Folks, I thought I was quite handy with household DIY.. but I have a very silly issue.
I am wiring 6 halogen downlights into my camper. 240volt.
I want a dimmer switch too, question
does it go inline i.e. break up a live, or inline neutral?
or does it 'sit' between live and neutral?
On the packaging it said, wite Com and L1 whatever way around you wish, job done.
I took a Neutral and a live and wired them in, the light came on when the switch was off! and then the lights got dimmer as i turned the switch up, and then the main plug fuse (and dimmer) blew.
I think my switch was underloaded, which caused the blow.
help ;)
John ..
jgra1
(Donor 2021)
x 36
it breaks up the 'live' i now think
This is for an on off switch but will be the same..
http://images.google.co.uk/imgres?imgur ... B%26sa%3DG
AndersDK
Unread post by AndersDK »
:lol:
It certainly breaks up the live :idea:
The neutral is then only used for the control circuit in the dimmer.
By the nature of live circuits AC voltage - the "live" and "neutral" is for you to decide on the incoming feed voltage pair - if nothing else identifies it.
I do hope you know what you are fiddling with : a lethal voltage supply and a potiential fire hazard :?: :idea:
Anders (DK) - '90 BX16Image
bxbodger
Unread post by bxbodger »
Are you using the vans power i.e. 240vac from an inverter with a cheap dimmer switch? If so, this could be causing your problem.
It's something to do with the waveform apparently, and that's all I know.........it stuck in my brain as it was the only interesting bit in my dads extremely boring caravanning mag!!
jgra1
(Donor 2021)
x 36
thanks both..
the plan is to use an inverter from 2 leisure batteries, and also to switch to mains hook up when on site.
However, for last nights test I was using Mains..
Anders I am being careful ;) extinguishers and AC testers all present ;)
J
jgra1
(Donor 2021)
x 36
I made this.. can anyone see the pic?
http://collect.myspace.com/reloc.cfm?c= ... 282891&id=
I dont really know how my space works yet ;)
this is bascially what i have at the moment
John
x 1491
I can see the pic. Looks OK. You don't actually need to connect a ring with all the lights on it - you can string them all on one leg, or even 2 legs if that's more convenient. You don't need to take 2 wires into the switch either - you can put a junction box in (or use one of the lights) and take the live to the switch down the red wire, then bring it back up the black wire as a 'switched' live (should identify with red tape). Of course you should also be using brown / blue wire these days too! :roll:
I'm just putting some lights up in my loft, and have a junction box with a terminal that's got red, black and brown wires all connected to it :twisted:
jgra1
(Donor 2021)
x 36
now I am confused ;)
sorry - AM using blue/brown wire, have no idea why I coloured them like that on Diagram hehe
Rich,
I used a ring as it fits well with the project, going around the roof of van.. If i used one (or two legs), wouldn't that be wiring the bulbs in series?
I only have one wire going into switch? and one coming out? both live (brown)
[quote] then bring it back up the black wire as a 'switched' live
run that by me again
J
pug_owner2002
x 3
Unread post by pug_owner2002 »
Just out of curiosity are you using mains voltage halogen lights or the type that use a transformer?
If its the type that use the transformer you have to buy a special type of dimmer switch.
R Reg Phase 2 306 DTurbo (Blaze Yellow) (Sold)
X Reg Phase 3 306 1.4 LX (Sold)
03 Renault Scenic Dynamique +
03 Seat Leon 1.9 TDi
52 Nissan Almera 1.8 sport+
jgra1
(Donor 2021)
x 36
mains....
jgra1
(Donor 2021)
x 36
http://viewmorepics.myspace.com/index.c ... =107282891
if the above link doesnt work...
John
AX_Man
Unread post by AX_Man »
RichardW wrote: Of course you should also be using brown / blue wire these days too! :roll:
:twisted:
Of course you'll need to get it inspected too (new electrical circuits in houses have to be council inspected) ...
I believe your camper van insurance will also see this as a modification and may demand a certificate.
PS I am not joking on this!
jgra1
(Donor 2021)
x 36
thanks.
look at this pic? this is the switche's own wiring diagram. shows L and N wires going in.. this is why I am confused? (not just L in and L out)
http://viewmorepics.myspace.com/index.c ... 1134445024
jgra1
(Donor 2021)
x 36
all, i think its finally clicked into place
let you know
BernieLugg
Unread post by BernieLugg »
FrenchCarForum wrote:Not a Forum for non French car problems. Nonsense posts may be deleted!
Try an electrical forum - or if you are unsure in any way shape or form about what you are doing with 240v AC electrics refer to a qualified electrician.
BX
Xantia
Shed
Set of Spanners
Kettle
