I have seen a posting on ebay that says it can boost your performance by 25 BHP. Are these for real or just a gimmick.
M Reg Xantia 1.81
mod on ebay
AndersDK
Sure you did not mis-read it ?
Should be at least 250 Bhp ?
There are ohmic resistors sold in "goldplated" packs ready to provide you "loads" of extra power. They work by increasing the engine temp sensor resistance, fooling the ECU to think the engine is cold. This makes for a constant choke function providing extra petrol - constantly.
At best it will indeed give you a tiny boost.
But at a cost of a constanly higher emissions and fuel consumption.
Must be compared with the toilet paper filter packs sold years ago - claiming you never had to replace your engine oil again.
Or the resistor to put in series with your ignition cable to "up" the spark power.
Or the blinking LED devices claiming to stop any corrosion in your car.
Or the magic stick to dip down the petrol filler neck to constantly catalyst more power to the engine.
Or the electronic computer chips to glue on the valve rocker cover - providing you with at least 25 Kangoo points - pr device.
Or - etc.. etc..
If just a single one of these devices did what they claim to do - they would already be fitted from factory ...
That would be much cheaper than doing the elaborate investing in any further engine developments.
Or - etc.. etc..
Anders (DK) - '90 BX16Image
- x 1240
mallyg
The posting reads "You would be buying a Performance Boost Resistor, which would add 5-20 BHP to your engine. it will fit anymake and model fuel injected vehicle that has an ECU, but not turbo or diesel models. it takes about 5 minutes to fit, and can be removed without any adverse effect to your engine. so you can put it in your next car.
all you do is attach the resistor to the inlet air temperature sensor, which connects to the ECU. the ECU then alters the ignition timing slightly, which is what gives you the boost in power. this will, however, result in you using a little more fuel.
for your money you will get the resistor and a copy of the universal fitting guide. if you are unsure about fitting it, then get someone with a bit of mechanical knowledge to help you, as i cannot be held responsible for wrongly fitted items"
1995 Xantia 1.8i Dimension
philhoward
- x 1240
robyoz
davethewheel
- x 1240
