ML5T gearbox filler plug
handyman
Unread post by handyman »
Hi, anybody know where the filler plug is on an ML5T gearbox, the type fitted to an Activa.
BOL only shows earlier or lesser gearboxes.
Handyman
frankielunn
Unread post by frankielunn »
If its any help i just changed my oil on a 2.0 litre 16v xantia,i took the nearside wheel off and looked at the end of the gearbox facing you... there are 3 bolts looking at you the bigger one is the filler, i think a 16m socket it did it tho i can't be sure now.
handyman
Hi frankielunn,
Thanks for the reply but the 'box on Activa is ML5T and I have found out where it is! Back of the 'box, on the diff casing. I sometimes wonder if the designers at PSA have a warped sense of humour, with some of the bad designs they come up with.
Handyman
frankielunn
ok handyman glad you found it...i must admit it took me awhile to find mine and i was searching in the area you mentioned but was careful not to open too many bolts as i found out to my cost once upon a time.there are 2 sump plugs on my sump and i took both off and only put one back and filled her up forgetting to replace both good job i didnt drive away before i noticed a big puddle forming on my drive.
