My Xantia has decided to start playing up and I now have a problem starting the car.
Key in ignition, turn to start and the solenoid just clicks. The problem started a few weeks ago, very intermittently but now seems to be permanent, until I can repair it.
This afternoon, I stripped down the wiring and cleaned any suspect connectors, like the multi socket under the battery tray. Checked all the leads for continuity and shorts, all seem ok.
Disconnected the terminals to the solenoid and cleaned off the oil on them, reconnected and still no start. Tried jumping the starter motor with ignition on and a large cable from +ve battery terminal to starter. All it did was whir, solenoid not clicking in to throw the starter gear.
Questions: Is the solenoid knackered? Could my fault lie with the ignition switch? Is there a cure or test for knackered ignition switches?
The battery is relatively new and showed no faults with a Nolten discharge tester, so it ain't that.
Any positive comments to resolve the problem would be much appreciated as I am supposed to be driving to France on Sunday!
Handyman
