Hello!! My C5 key fob was working fine, then all of a sudden one day last week I could not lock/unlock remotely or partly open the windows after locking (a C5 feature). New battery was my first thought and so new fob battery installed - no joy. Anyone have any ideas how these RF fobs can be tested? Many thanks,
John.[/b]
C5 Key Fob
johnway
C5 Key Fob
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
JohnD
- x 72
Seem to recall this advice given on another forum. Disconnect the battery for ten minutes. Reconnect and start the engine. Switch off and try the key fob. Maybe need to repeat the engine starting a couple of times.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
johnway
Yep, tried this - still no joy. Thanks for the suggestion.JohnD wrote:Seem to recall this advice given on another forum. Disconnect the battery for ten minutes. Reconnect and start the engine. Switch off and try the key fob. Maybe need to repeat the engine starting a couple of times.
Regards,
John.
KevMayer
I had this happen on my C5 a few days ago. Then it just started to work again.
What I suspected had happened was that their is a security feature built in which is similar to the one I have on my Audi A4.
If the Audi detects another radio signal whilst I send an open then it locks out. To reset it You haveto press and hold the open button for 10 seconds.
This is what I did on my C5 and I think it worked.
Try it..a 10 second burst. See if it resets the link.
Good Luck
Kev
Good Luck
Kev
Cheers, Kev
johnway
Hi Kev,KevMayer wrote:I had this happen on my C5 a few days ago. Then it just started to work again.
Good Luck
Kev
Tried this - still no joy. Thanks for your suggestion.
Regards,
John.
JohnD
- x 72
KP
- x 27
mooseshaver
My C5 sometimes does this, but it fixes itself after about 30mins I think.
If you put the key in the ignition and turn it on to electrics, and then press one of the buttons. I think that reprograms the key when you change battery?
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
johnway
Hello,mooseshaver wrote:My C5 sometimes does this, but it fixes itself after about 30mins I think.
You are right!! I went to a local Citroen Dealer who was able to test the fob and found it to be working OK. Helpful chap also tried the reset trick i.e. turn on ignition and press the unlock button for 10 secs. After 2 goes at this still nothing but he told me to keep trying and if still no joy then the ECU would need re-programming (a £35 job). Drove the car back home, switched off and went through the reset procedure again - this time twice with the unlock button, then once with the lock button. Joy oh joy, I heard the wonderful sound of door locking and both indicators flashing!!. Job done - fob back in remote action.
Regards,
John.
johnway
Hello,KP wrote:Same PHP coding fault i had earlier i bet where it was saying ti couldnt send a message per chance?
Have you tried the sapre fob at all??
I don't have a spare so no is the answer! Thanks for your suggestion and problem now resolved.
Regards,
John.
johnway
Not even after about 10 goes !! However, following Citroen's advice it is now working.JohnD wrote:Not even after three goes!!!!!!!!!! - Sorry!
Regards,
John.
