Constanly clicking indicator relay
stingray
Unread post by stingray »
Over time an intermittent fault on my 1996 106 1.5 XLD has got worse and now the indicator relay constantly does a high sped click (as though a bulb has blown) when the indicators are turned off. Whilst clicking neither the dashboard bulb or the actual indicators flash. When operated from the indicator lever all of the indicators operate correctly.
I have tried nudging the indicator lever in both directions but this does not stop the clicking.
Any ideas would be appreciated.
OwenP
Unread post by OwenP »
Try checking the relays. I had a very similar sounding problem on my 96 405.
It has only happened the once however I think when getting out or back into the car after that journey I kicked some of the relays in the footwell. Its not happened since. Of course that might be pure coincidence, but they might be the next best place to try.
2001 406 Rapier 2.0 HDi 90 Estate - Sold Scrap after being viciously attacked by a falling tree
2001 Toyota MR2 1.8 VVTi - To be sold for spares/repair - dead gearbox :(
2014 Seat Ibiza Eastate 1.4 FR ACT (bought in an emergency, but a nice enough low mileage car)
alan s
RIP 2010
x 6
Unread post by alan s »
After a while, the Xantias can also tend to do this too.
An old trick with them is to get into the car and before starting off, turn the "hazard" light on and leave them flash for about a minute. Switch them off and the problem should be gone.
It may take a few of these treatments, but in most cases with the Xantias, it does the trick.
Seems the contacts get slightly corroded inside the unit and tyhis basically "blows it off" and gives a cleaner contact surface thereby eliminating the cause.
Can't speak for a Pug, but has to be worth a try.
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
steelcityuk
Unread post by steelcityuk »
You could try taking out the switch, remove the top and clean all the junk out of it. This has worked on both my 405 and Xantia. Only takes 15 minutes.
Steve.
not applicable
stingray
Thanks for all the help, I think I have narrowed it down to the switch as suggested by steelcityuk, I'll have a go at taking apart today and giving it a good clean
