Afternoon all. Got a couple of questions about airbag wiring numbers/codes. As my Xantia never had a airbag fitted to it as standard (its a 93 MY on a 'L') a previous owner has retrofitted one to the car .....All of the components seem to have come from a april/may 1996 model year from what I can tell from the stamps on some of the components - the steering wheel, seatbelt pre-tensioners and the trigger sensor under the center console. What and where do the following wires go to or control???
Orange wire - Number 478
Yellow wire - Number CC4
Green wire - Number MC02K
Brown wire - Number 6506
Anyone got any idea? Much appreciated - Anthony
wiring question
NiSk
I have a funny feeling that retro fitting airbags is something that only the original manufacturer is permitted to do . . . .
You may well bump into some difficulties when you MOT it.
//NiSk
//NiSk
'85 BX 16TRS, '91 XM injection 241,000 km (company car), '93 XM TD12 (515,000 km), '98 XM 2.5TD Break (320,000 km)
Sturdybloke
weety
i didnt think the air bag was part of the actual test.........
its not listed as a testable item here
http://www.motester.co.uk/cog.html
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
Sturdybloke
weety
no sorry....i was replying to NiSk as well....Sturdybloke wrote:Its not part of the current test. I was just pointing out to NiSk that in the time that I have had the car the "retrofitted" bag has never been a problem (so far). Any idea on the numbers on the wiring (listed above)?
