Hi Guys
When locking up my 95 td xantia and putting the deadlocks on the led on the dash does not flash it just remains dimly lit all the time even when the alarm is not activated although the remote central locking is working perfect and so,s the deadlocks.
any ideas guys
pete.........................
xantia td alarm led problem now sorted
[email protected]
Drives
51 Reg Citroen C5 SX 2.0 16v
[email protected]
anyone
the alarm led on the dashboard does not flash like it should when its activated
there must be someone out there who knows something about these maybe it needs resetting or somthing or is the alarm ecu not working properly even when i unlock the car with the remote the indicators do not flash like they should.
Anyone
Pete...........................................
Anyone
Drives
demag
- x 102
Sounds like a bad earth to me. Possibly on the dash somewhere.
And Peugeots are famous for bad earths!
Citroens as well I think.
Dave
[email protected]
[email protected]
hi guys
ok ive got to the root of this problem after checking out the bulb on the dash (the bulb was not dimly lit as i first said it was not on at all i was looking at the colour of the bulb
) and then the control box under the passengers seat (i tried the one out of my other xantia that i know works) that did,nt work so i tried the box that was,nt working in my other car and the box worked.
so then i did some checking and found there was no power in the alarm system scatching my head i thought check the fuses and low and behold i found the problem someone had removed the fuse for the alarm system so i replaced the fuse and everthing worked ok just had to reset the alarm with the switch on the dash then all was ok.
now the only problem i have there now is the switch under the bonnet is not turning the siren on or off it just keeps going round and catching now and agian and the siren is turned off. i know this becouse it cought once and i turned off the siren, now i cant turn it back on agian.
Drives
KP
- x 27
[email protected]
Thanks KP ill try that ill let you know how i get on
Drives
- x 1476
mezuk04
[email protected]
Hi Guys
Well the alarm has been fine no problems
. But ill have to look at the switch under the bonnet i tried what you said KP said but it made no differance so im going to have to take it apart. i turned it off, now i cant turn it back on again it just keeps going round!.
. Then maybe i upset the neighbours
but i know everythings ok so that,ll not be the case.
Drives
[email protected]
